OP
Discuss rayburn electrical connection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Bobby - were are installing the electrical pump right now! - did you fix the rayburn cable to the pump? then the pump to a spur socket?i think it is designed to shut down the pump if the water temp in the boiler gets too low. thats how i wired my parents and it works brilliantly
This member hasn't been active for twelve years you may want to start a new thread.Hi Bobby - were are installing the electrical pump right now! - did you fix the rayburn cable to the pump? then the pump to a spur socket?
Reply to rayburn electrical connection in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
