RCBO to fit MK | Page 2 | on ElectriciansForums
Discuss RCBO to fit MK in the Electrical Tools and Products area at ElectriciansForums.net
along with wylex and crabtree and an off shoot of ABB!! good old electrium they know how to corner a market!
Domestic customer , the CU cupboard is only 250mm wide so had no choice there are 7 rcbo's to go in so around 180-200 after mark up for the CU. Plus I'm putting in a rod as its a tt currently. gas and water bonding as they aren't there at the moment and connecting up the new shed supply then test, all in think it's coming in at around £620. forgot to add £120 for the rod install as this was an addition if EDF couldn't convert to PME :D
Don't mind me while I bump some old threads. Just doing the rounds. Ignore the thread if it's not current topic, it'll soon drop off the list, but if the thread interests you, feel free to reply. :)
Reply to RCBO to fit MK in the Electrical Tools and Products area at ElectriciansForums.net
Who knows? There's this, in the OSG app H: "Permanently connected equipment should be locally protected by a fuse complying with BS 1362 of...
I usually use the 62606 with the RCD/OCPD type because it can be both.
