RCBO's tips and suggestions | Page 2 | on ElectriciansForums
Discuss RCBO's tips and suggestions in the UK Electrical Forum area at ElectriciansForums.net
Judd
Liverpool
Has anyone got any tips and suggestions for terminating RCBO's neatly in consumer units?
I'm more than happy with how I present my dual RCD and MCB CU's but I find that the flying neutral and earth from RCBO'S don't hold their Shape like a solid core cable would and often sag and look unsightly.
Any pictures aswell would be a bonus
Better, but green ferrules are for 6mm. Not only do they look better when properly ferruled, but it's against the regs not to!
[ElectriciansForums.net] RCBO's tips and suggestions
Or 16mm if you like the German ones...
Either way those pictured are way too big and will not crimp correctly, even when you graunch them up with the screw...
You've been buying those cheap Chinese eBay specials haven't you? If so they'll be designed for 6.18mm cables...
had them for years from subbing to a major thyristor drive factory. they sat in what's called a "free issue" bin. i.e small parts that don't need to be requisitioned from stores. used there on panel building.
Reply to RCBO's tips and suggestions in the UK Electrical Forum area at ElectriciansForums.net
Thank you, that's a really helpful post, nice & clearly stated and helps me clear up a lot of confusion on this matter.
2 3 4 5
6K
