RCD a but slow. Time for a change? | Page 2 | on ElectriciansForums
Discuss RCD a but slow. Time for a change? in the UK Electrical Forum area at ElectriciansForums.net
Electron
Altrincham, Cheshire
I tested a customers BS4293 MEM 100A, 30mA RCD, which is about 25 years old, after it tripped overnight. The trip time at x 1 was 207.2, 78 and 54.2 ms at 0 deg. and 68.6 ms at 180 deg. I know that the limit is 200 ms, so one reading was slightly over, which is why I repeated the test. At x 5 it tripped at 50 ms at 0 deg. and 41.5 ms at 180 deg. So, again both over the limit of 40 ms. No trip at x 1/2.
Do these results mean I have to change the RCD? Or is there any tollerance? If so, can only get used identical replacement from the internet. Or should I change it to a RCD to BS EN 61008-1, like a Wylex 100A 2 Pole 30mA RCD?
It is unusual for a 4293 device to trip and then fail under test with a meter. What range of MEM is it.
Does this help?
[ElectriciansForums.net] RCD a but slow. Time for a change?
Does this help?
I wonder if it had been tested every three months for the last 25 years?
No. I always say to customers "Can I assume that you test the RCD's every three months?" They look at me as if they have broken the law!
Does anyone ever check the RCD? I only ever do it when someone pays me!
Had your customer tested the RCD by using the test button? could be the mechanical mechanism had become tired or clogged up if no testing had been done.
There is a replacement RCD available for these Memera 2000 boards, but costs around ÂŁ130 when I checked recently (EAM1002H, if I recall). In my case, I'm changing the board, rather try to maintain a board where half the circuits would still not have RCD protection.
Hi - sometimes they will come back into spec after "some exercise". Failing that, I'd be inclined to change it all out.
They might, but it's still not acceptable as they have already failed the test.
It's no use telling people to exercise the device with the test button several times before each time they have an Earth fault.
The device has failed.
Does this help?
Mine gets tested every time my other half decides to toast a tea cake and a current gets stuck between the casing and heating element!
Reply to RCD a but slow. Time for a change? in the UK Electrical Forum area at ElectriciansForums.net
