hi all, Am i right in believing that if i install An RCD controlled garage cu fed from Dual RCD Cu i will cause problems with unwanted tripping???? It is not possible to come off unprotected side. Any advice much appreciated
Discuss RCD Advice in the Australia area at ElectriciansForums.net
you couldnt put a 100ma RCD into the main board as all the other circuits would be protected by 100 ma when they should be 30mawould you not just put a 100mA rcd in? or do we need to know more info like har foar away the shed will be what it will be supplying etc?.
No it is not better to feed the garage from the main DB's rcd in most cases. Its just this time the fella has no other option. In an ideal world it would come from its own rcd or be an armoured and not need an rcd at supply enddon't know just trying to understand tbh, I thought if you have a outbuilding supply like that you are supposed to put in a 100mA rcd because of discrimination.
So its better to have the shed protected by the main DB's RCD instead of instaling an rcd for said shed?.
What I am not understanding is why cant he install a CU in the shed with an RCD that is configured so that any faults from shed will only trip the shed rcd? (discrimination). That way the RCD from main DB will protect the cable supplying the second CU and other RCD will protect those circuits.
Sorry if I have missed something obvious.
why not use rcbos in the shed for each circuit?
Reply to RCD Advice in the Australia area at ElectriciansForums.net
