RCD inspection and testing | Page 2 | on ElectriciansForums
Discuss RCD inspection and testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Not if you are using the correct equipment.
That's the point I was making earlier, if all testing is carried out with a plug in BS 1363 lead (non intrusive) then you can be shown how to simply harvest results.
Some great advice from the guys there , one thing that springs to my mind is has there been a recent periodic done on the installation , only reason im asking is do you know the ring conditions all readings are satisfactory etc , it is great to see an installation being checked on a regular basis , but if there are some defects on the rings etc open circuits on rings etc it could demine the tests you are carrying out , if a periodic had been carried out at the tests were all ok then great idea makes sense , dont mean to be negative and its just a thought , oh the other test you could to is the ramp test of the RCD to mkae sure its tripping at the required ma rating
if i hit it with a hammer and it breaks within 300mS ( 1lb. hammer ) and within 40mS ( 5lb hammer ) is that a pass?
Reply to RCD inspection and testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It can also mean lasts or continues for two years.
