Rcd main switch | on ElectriciansForums
Discuss Rcd main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
haj
East Yorkshire
Hi Guys Rcd main switch on board so do you need sup bonding as all circuits are Rcd protected? I know realy need to upgrade board act customer reluctant. Cheers Haj
If all circuits in bath/shower room are 30ma rcd protected,required disconnection times are met AND you have a continuity reading of less than 1667 ohms between extraneous conductive parts and conductive parts in the bath/shower room,you dont need supplementary bonding.
Reply to Rcd main switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Also use a tails gland and clamp if available and make sure tails are secured to a wall. The danger here is a live to earth fault in the Consumer Unit
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
