W
Wee wire
Hi looking a little help. Replaced a consumer unit in a house with a contactum 8way dual rcd split board. After finishing it I tested with rcd tester at 1 time and 5 times with the rcd tripping in correct times. I went to connect up boiler after with the cable dead I cut it but the rcd would not trip. Then at the db I linked out the earth bar and neutral bar and neither rcd tripped to try and see if it would anyone any ideas?
