S
Skimpy Wan
If the test button doesn't work wouldn't you change the RCD? Personally, I would so that it can be tested by the end user.
Discuss Rcd not tripping and ramp test more than 30ma in the Talk Electrician area at ElectriciansForums.net
I can plug an MFT in and do a ramp test. The end user can't. Therefore I can confirm that the RCD trips within the parameters of its design, but it would need replacing to check the device regularly.
Functional test
Just a thought......and I'm no expert testing. If the installation meets the TN requirements (as stated earlier) i.e. disconnecting times are met then the RCD's if installed for additional protection , as daft as it may seem do not need testing.
Reply to Rcd not tripping and ramp test more than 30ma in the Talk Electrician area at ElectriciansForums.net
