View the thread, titled "RCD nuisance trips" which is posted in UK Electrical Forum on Electricians Forums.
Siddell
Hi there,
I've got an old, Wylex, 4-way, rewireable fusebox, water mains providing my earth (PME to come) and a 100A service fuse. The circuits are:
i) ring main
ii) lighting (two circuits in single fuseway, one of which is a single light)
iii) immersion heater (not used)
iv) cooker and hob (actually leads to a double socket that feeds these appliances).
Once I've sorted my bonding, I'll get someone in to connect to the new PME terminal. What I need to decide, though, is what RCD protection to get. What I would like is to keep the fusebox and simply have someone install one, all-encompassing RCD. I am aware of regs 314.1 and 314.2 (which ordinarily even a dual RCD, split-load CU doesn't seem to satisfy) and that the only practical solution to that is to pretty much have each circuit individually protected by RCBOs, so would like to park that issue aside for now, given that I don't mind nuisance trips as long as they are infrequent, which brings me (finally) to my questions!
What is the likelihood and nature of any nuisance trips if one RCD were installed for the whole fusebox?
I know this may be something of a crystal ball question, but really I need to weigh up the chance and cost of problems (likely a new CU) against the cost of installing a single RCD. The only time a fuse has blown in the two years I've been in the house was on the lighting circuit, so no other obvious signs of earth leakage - that said, I probably have a sh*tty earth right now and any earth leakage I assume will be magnified once the PME connection is made.
To what extent could this be mitigated using a 100ma RCD (as opposed to 30ma)? Where is a 30ma RCD required? Is there an inherent firerisk with rewireable fuses slow fusing if only slightly overloaded?
Thanks for taking the time to read this and for your thoughts.
If the incoming water connection and gas connection are close to the CU, then i would say its probably a bit on the strong side. I would assume this is a smallish property. Hopefully all the cables are pvc and you have cpcs on all ccts. If if if if - then as mentioned the CU with a couple of RCDs is cheap as chips, i would not spend a penny on an old wylex board .An electrcian could do this in a couple of hours. I think there must be contingency in there for the unseen / unknown.
Oh and when i looked at my niece's new house purchase, i immediately installed a standalone RCD as a matter of course before re-wiring it a couple of years latter, she had rubberised cable and considering all the additions over the years and some bad practice, she had no nuisance trips in that time
dont know if theres much vir around now still in service.....found some at my mothers the other day though.....out came those snips..lol...
Got another quote. 395 plus VAT. Still essentially a day rate for a consumer unit change.
Generally a day rate for CU change, plus testing and paperwork?
I've just had a PME terminal installed so the meb needs upgrading to 10mm, although I have said I will lay all the cable for this. Sparky seems to specifically want to make the meb connections himself, although I thought this wouldn't matter as it's no longer notifiable work?
Reply to the thread, titled "RCD nuisance trips" which is posted in UK Electrical Forum on Electricians Forums.
