RCD protected sockets | on ElectriciansForums
Discuss RCD protected sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
kiwi
I have a cafe to re-wire and they have 2 freezers that Iam going to wire dedicated sockets for. I dont want to put these with RCD. Will it be possible to use SY cable as opposed to SWA cable will be in plastic trunking surface. I was on the understanding has to be more than 50mm flush, steel conduit or earthed metal sheath, is this still the case with commercial property ? skilled commpetant opperators and all that. Thanks
Why not use T&E in trunking?
As long as the cable is surface, and the socket is labelled accordingly, then no RCD required.
Reply to RCD protected sockets in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think I've found the answers to my questions... I can just do a straight forward wiring i.e. connect the 3 wires from the armoured cable to...
Nope, totally fubar.
