rcd protection- barber shop | on ElectriciansForums
Discuss rcd protection- barber shop in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Earth
afternoon guys
think i know answer to my question but wanted to double check
my barber (quite friendly with him so wanted to help him out!) asked me to do his barber shop eicr (only a small 6way c/u) anyways just had a brief look and its an old board with wylex push in reto 60898s- no rcd protection
the shop is ground level
would you guys c2 no rcd protection to socket outlets or with commerical is it different?
head says it just same as it would be for domestic so c2
If a non rcd protected socket was right by an external door and likely to be used for outdoor equipment C2, otherwise C3 for the ground floor sockets. (Providing acceptable EFLI readings obtained)
Reply to rcd protection- barber shop in the UK Electrical Forum area at ElectriciansForums.net
2 3
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
