rcd protection- barber shop | Page 2 | on ElectriciansForums
Discuss rcd protection- barber shop in the UK Electrical Forum area at ElectriciansForums.net
J.C.E
Earth
afternoon guys
think i know answer to my question but wanted to double check
my barber (quite friendly with him so wanted to help him out!) asked me to do his barber shop eicr (only a small 6way c/u) anyways just had a brief look and its an old board with wylex push in reto 60898s- no rcd protection
the shop is ground level
would you guys c2 no rcd protection to socket outlets or with commerical is it different?
head says it just same as it would be for domestic so c2
Are they likely to be using Portable /mobile equipment outside?
Do any unprotected sockets give rise to danger?(external influences)
This would influence my choice of code
Tis not the socket which gives rise to danger but appliances using said sockets. Don't worry about the ifs and maybes the fact is they have no rcd protection and this is the statement of fact you use, Code it, move on.
[ElectriciansForums.net] rcd protection- barber shop
or with out extension leads out side .
I'd bring it up to current regs and put a split load board in, the equipment being used is all handheld used day in day out by an unskilled person and members of the public will be in the premises. What's the point in having regs if no one is willing to bring old installs up to current regulations? Otherwise they'll be installs 20, 30, 40 years old that aren't to current regs but loads of C3's which never get done!
it is down to the test engineer what he thinks at the time .
I agree, can't really give a definitive answer without personally being at the installation.
However (in line with numerous electrical bodies) also can't generalise socket outlet's no rcd protection as C2. And in doing so declare thousands of older domestic and non-domestic installations as unsatisfactory.
.......................... How old is the installation?
That said a barbers shop, with plug in accessories and water ................. RCD would be a good idea............
If there are no stocks in freezers -to spoil ,
or things than despiratly need recharging overnight .
Pushing for RCD sounds more than sensible
(if a fault develops at night , shop is more likely to still be there - electrics full of hair)
(It's the reason regs tighten --Improve )
Do the insurers think there should be RCD protection? And do the manufacturers of the shavers say the equipment is recommended to be used with an RCD? Just wondering. But I would go with C3 as there would no doubt be a significant improvement to safety for the barber and customers. Maybe RCD sockets?
I can't really see there is a likely danger taking into account the history i.e. how many people have been harmed for lack of an RCD? Probably none. Given the caveat of post no. 4
The clippers and hairdryers get a huge amount of wear and tear on the flex near the appliances with all the constant moving about. This puts the risk of shock at a higher level than most portable appliances. Just something to bear in mind generally.
C3 with a tin hat for me Mr. Wilkes.
Reply to rcd protection- barber shop in the UK Electrical Forum area at ElectriciansForums.net
2 3
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
