RCD protection in garage | on ElectriciansForums
Discuss RCD protection in garage in the UK Electrical Forum area at ElectriciansForums.net
If I have a distribution circuit (to a garage with accommodation upstairs) does the CU in the garage have to have RCD protection or is it sufficient for the main CU in the house that feeds the garage to have RCD protection? Just wondering about regulation 411.3.3 additional protection as there will be sockets and a shower in the garage.
Thanks for any replies
D2E
It could be either.
Have a little think about why we need rcd protection and not just for sockets etc.
It can depend on the installation method.
Sent from my iPhone using Tapatalk
Is the garage a TT conversion if so all circuits will require RCD protection.
One question what sort of loading will the garage have a shower sockets and lighting may be a bit too much to supply from a spare way in the main CU.
All circuits in a room containing a bath or shower require additional protection.
D2E
You say accommodation upstairs. Is it for a member of your family or a lodger/rental? If so, they will not want to be knocking on your door to reset an RCD.
Reply to RCD protection in garage in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Cheers guys, enjoyed reading all the responses. I'm an apprentice and it was a conversation that came up at work between two electricians...
2 3
