RCD refuses to switch on (up) | Page 2 | on ElectriciansForums
Discuss RCD refuses to switch on (up) in the UK Electrical Forum area at ElectriciansForums.net
Ayr
I’ve run a 2.5mm t&e cable from a 16a cu in the house to the shed all in 20mm plastic conduit - say 7m. The shed has a BG garage unit with RCD and two ways, 5 and 16a.
In the shed is a final ring circuit with a spur for a fan and a LED style fluorescent fitting. The RCD refuses to switch on. Even with both ways switched off the RCD will not switch on.
I have checked all connections and can find nothing. I checked the mcb, previously used for an immersion heater, by connecting the lights wire into it and everything was okay.
Wired brown into mcb, blue to neutral bar and earth to earth bar all on the non-elcb side of a MEM cu. Other end as per instructions into RCD.
Any ideas please? I simply wanted this up and working before bringing a sparky in to test and certify.
I'm beginning to think the N is connected to the wrong busbar in the house, I'm confused with the OPs description of how it is wired I have asked if he can post a pic of the house CU internals, just to be sure in my mind, hopefully he will.
Naah found em and it’s not
[ElectriciansForums.net] RCD refuses to switch on (up)
lol .
Reply to RCD refuses to switch on (up) in the UK Electrical Forum area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
