RCD refuses to switch on (up) | Page 3 | on ElectriciansForums
Discuss RCD refuses to switch on (up) in the UK Electrical Forum area at ElectriciansForums.net
Ayr
I’ve run a 2.5mm t&e cable from a 16a cu in the house to the shed all in 20mm plastic conduit - say 7m. The shed has a BG garage unit with RCD and two ways, 5 and 16a.
In the shed is a final ring circuit with a spur for a fan and a LED style fluorescent fitting. The RCD refuses to switch on. Even with both ways switched off the RCD will not switch on.
I have checked all connections and can find nothing. I checked the mcb, previously used for an immersion heater, by connecting the lights wire into it and everything was okay.
Wired brown into mcb, blue to neutral bar and earth to earth bar all on the non-elcb side of a MEM cu. Other end as per instructions into RCD.
Any ideas please? I simply wanted this up and working before bringing a sparky in to test and certify.
I worked for years in electrical wholesalers and understand matters fine.
I reckon I do have a fault, however I cannot understand where. I tripped the in-house mcb and then disconnected the RCD, now when switched up it stays up.
Did you disconnect the load side of the RCD, i.e. remove your wiring?
The neutral is in the correct neutral bar, the OP has told us twice that the supply to the shed CU is from the non-RCD side of the house CU and the picture proves it.
Easy Tiger. In any case I've already said all that, in a subtle way. So your guilty of plagiarism.
Keep up, you can learn a thing or two from me. :)
PS, thought I was mentoring you anyway. Not turned up at class for a while. Do ya wanna talk about things?
I'm not 100% certain as it is difficult to tell, but I'm another vote for the incoming supply neutral at the garage CU is in the neutral bar rather than the RCD incoming terminal.
I am 100% sure it's a DIY who thinks he knows more than he does. Mind you, he's served his time...…….working in a wholesalers. :rolleyes:
Reply to RCD refuses to switch on (up) in the UK Electrical Forum area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
