rcd requirement | Page 2 | on ElectriciansForums
Discuss rcd requirement in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
manjit
london
Hello just wanted to ask, my friend has done an extention, and new wiring, with new lighting, ring main, my friend has all rcbos in CU, and he has run the wiring, and contected to rcbos, but he has been told that the new wiring, i.e that the extention wiring should be rcd protercted, it dosent matter if each of the circuit is protected with rcbos,
i.e the lighting circuit is protected by rcbo and so is the ring mains and the cooker, does it still need rcd protection.
Any help would be really apprecitaed.
thank you
He replied to you very quickly then. Is he there with you now?
No he had sent me the pictures and chatting with him on whtsapp
[automerge]1571838901[/automerge]
It might be but I will have to check, if 2.5 then, he will have to reduce the rcbo to 32amps, correct
Whoever is doing the work should not be doing it if they do not know whether they should have the rcs protection or not. Whether it's you or your friend. It's as simple as that.
Reactions: DPG
Incorrect, the largest the RCBO could be for 2.5 would be 20A,
Hello Guys thsi bill , friends of manjit , who helped me out by joining this , i was told to join too as there some questions , he could naswer and here i am. the solar sysetem is 1.75 kw.
Status
Reply to rcd requirement in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
