RCD Test Results | on ElectriciansForums
Discuss RCD Test Results in the Electrical Course Trainees Only area at ElectriciansForums.net
Spark2020
Trainee
Nothwest
When testing (30ma RCD) to (BSEN-61008), am I correct In thinking you record the lowest values & not the highest value reading obtained @ x 5 In, for the schedule of test results, for example.
X 1/2 In-No trip
X 1 In-0-180-Under 300-ms
X 5 In-0-180-Under 40-ms
Check test button for operational purposes
Thanks in advance, sorry if sounds daft, I've only just started posting on the forum, I think I've cracked it but not 100% sure on this cheers.
You always record the highest value.
Thanks Westward,
You always record the highest value. The question is not daft ask whatever you wish that is the purpose of the trainee forum.
Thanks westward10, I've got it now just wasn't 100% sure on this cheers.
grammar police intervention. if 2 values it's lower and higher. if more than 2 it's highest and lowest. like if you have 2 kids. older and younger, not oldest and youngest. i'll get my coat now. (before some smartarse says his kids are twins. :p:p.)
Reply to RCD Test Results in the Electrical Course Trainees Only area at ElectriciansForums.net
