Hi
Ive got a question regarding RCD tests.
If a DB had 7-8 ccts on MCBs all covered by a Main RCD, should we do only one cover-all test on the main RCD, or record an individual RCD test for each circuit?
Other sparkys on my firm have been doing an RCD test for each circuit, effectively testing the same RCD 8 times.
What is the correct procedure?
