RCD Times on EIC | Page 3 | on ElectriciansForums
Discuss RCD Times on EIC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yer save the trees ! will we ever reach an edition without ammendments ? doubtfull although what edition will require emergency lighting to be installed in domestics ?
If you are using the SOTR from BS7671:2008 or GN3, then to record rcd tripping times at times 5 you will have to draw in another column after column 14, also draw in another column at the end of 15 to record 80% Zs values. After July 2011 the new SOTR sheet will incorporate all of the necessary data required.
Reply to RCD Times on EIC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Yes Table 3A that was in Appendix 3 of the 17th edition of BS7671 and in BS 7671:2018 (Blue Book) up to the release of BS7671:2018 +A2:2022 (Brown...
Thanks for the advice, I actually had no idea about the HMO licensing rules so have learnt a lot. Just did a search, its not licensed as an HMO...
