rcd trip on my shower | on ElectriciansForums
Discuss rcd trip on my shower in the Australia area at ElectriciansForums.net
M
mitchell0239
Hi Guys,
I'm new on this site and have joined for some info on a problem which is driving me mad...
I have installed a 8.5kw shower, run a 11m 10mm t+e from the 40a MCB to a 45a on/off switch and then to the shower..but when i turn the shower on it trips the RCD on the splilt load CU and the MCB stays on..so i power it back on..removed the shower, checked the voltage and have 240Vac..but as soon as i turn the shower on again it trips..any ideas pls????
Its the second shower as this was happening with the new one i put in last time, so i thought it was maybe the shower?? Bought a new one and the same thing happening to this one...can i use a 40a mcb and a 45a on/off switch or do they have to be the same??
Sky diving sounds good to me lol:d
Will double check it later when i get in from work..if it is on the correct n bar...any ideas what else it could be? Was thinking if its the rcd that trips then its gettin an earth fault from somewhere...could be the 10mm cable as i have fitted it under floorboards and wonder if i may have caught it with a nail or something else?? But if i had then i wouldnt get voltage would i? Im convinced its a problem in the cu
Safely isolate the shower...Electrically disconnect shower at shower end...Get suitable terminal block, and safely terminate into terminal block...Re-energise shower circuit...If it still trips, then it is a wiring/earth fault...start at CCU to see if N on correct neutral bar...work your way through the circuit, checking each connection at all points...
If the circuit energises ok when shower is disconnected, then fault will be at the shower unit, either incorrectly connected, damaged conductor insulation touching eathed point, or faulty internals in shower.
Yooj
Sounds to me like you need to do full test sequence on this circuit?
If you dont have access to test equipment then you can do as YOOJ has said but it is preferred to consult a proffessional electrician.
Reply to rcd trip on my shower in the Australia area at ElectriciansForums.net
There are two reasons for a fuse/mcb they are: 1) fault conditions - which must exist always, and be capable of operating for all points on the...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
