rcd trip on my shower | Page 3 | on ElectriciansForums
Discuss rcd trip on my shower in the Australia area at ElectriciansForums.net
M
mitchell0239
Hi Guys,
I'm new on this site and have joined for some info on a problem which is driving me mad...
I have installed a 8.5kw shower, run a 11m 10mm t+e from the 40a MCB to a 45a on/off switch and then to the shower..but when i turn the shower on it trips the RCD on the splilt load CU and the MCB stays on..so i power it back on..removed the shower, checked the voltage and have 240Vac..but as soon as i turn the shower on again it trips..any ideas pls????
Reply to rcd trip on my shower in the Australia area at ElectriciansForums.net
There are two reasons for a fuse/mcb they are: 1) fault conditions - which must exist always, and be capable of operating for all points on the...
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
