RCD Trip | on ElectriciansForums
Discuss RCD Trip in the Talk Electrician area at ElectriciansForums.net
Monmouthshire
Just put a Split Board in my own house (a bit of a upgrade going on) and a problem with one of the RCD's.
Last minute post this and stopped work for the night.
I have not done any fault testing at the min, as having a relaxing Friday drink. However Fully weird every thing but with the main Isolator ON and when I switch both the RCD's on, one of them trips after 1sec or 2sec. That is with all the other MCBs in the OFF position. Can't think what might cause this other than a faulty NEW RCD. Am I forgetting anything before I dive in on Sat Morning to look at it ( just bi-passed it for Friday Night to keep the lights on and left one RCD in Circuit and all is OK)
Should have tested before you went ahead and changed the CU no excuses, go and put the dunces cap on and stand in the corner, no house points for you bjkered
I had initially discounted Neutral Earth as had not tripped on old RCD or the way I have Left it.
Had passed my brain as Neutral in wrong place. Which probably meant the initial installation ( some one else, before I bought the house) was wrongly labelled ( luxury) or they had crossed up a ring main. Neutral wrong place was my first thing to-
morrow. Thanks
Agree borrowed neutral, and if you didn't wire the house then check upstairs, downstairs lighting, as common practice with some sparks was to put landing light switch positioned downstairs on the downstairs live.
as a temporary fix, try putting both lighting circuits on the same RCD. if that stops the tripping, then it's as post #10.^^^^^^.
Reply to RCD Trip in the Talk Electrician area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
