vini
I'm not even sure if I can properly explain this one. When the shower is switched on the RCD (1) on the other side of the board trips. The shower continues to work fine and when they come out they reset the RCD until the next person needs a shower.
When the hoover is switched on and plugged into the ring on RCD (1) side of the board the RCD (1) trips, but when the hoover is plugged into the ring on RCD (2) it is fine and works. Apparently the same thing happens with the kettle, sometimes. Other appliances are fine.
They did have a fire about five years ago and the place was partially rewired. A split board was put in about 2 years ago
IR tests are fine.
Neutrals are all correct.
Ring mains are not crossed.
IR tests are fine.
