Rcd tripping with no switch on after smart meter installarion | on ElectriciansForums
Discuss Rcd tripping with no switch on after smart meter installarion in the UK Electrical Forum area at ElectriciansForums.net
Desikeera
Uk
Hi
I am.from uk
I had a gas top up meter and a electric smart meter installation
Thought to ask my energy supplier to fit me a gas smart meter aswell
Their enginner came and said we will have to install the electric meter aswell so they will combine the smart thing on the display
But after installing the new smart meters
My rcd been tripping time to time even with all switch down on the main board
It did trip 2 times while he was here - but then worked absolutly fine he did open the unit and check and tighten all connectio
In last 5 hourd have tripped 2 times
Can anybody advise?
Strange because i already had an electric smart meter installation and never had this issue so why now?
Can anybody advise me?
[ElectriciansForums.net] Rcd tripping with no switch on after smart meter installarion
it has been suspected on another thread that the smartmeter transmitting it's data may trip an RCD in close proximity.
Thanks for your reply but strange i had a smart meter before this one never had this issue ?
Don't know why he changed the smart meter i already have, i even told him leave the old one its working pretty fine
I’d suggest that unfortunately you are going to need a friendly local sparks with testing equipment. A quick ramp test of the RCD with no loads on and all loads on, and measuring earth leakage will be conclusive quite quickly.
(If you indicate roughly where you are a forum member might offer to help.)
The alternative is turning all breakers to the left off and waiting a few hours and seeing if it trips and that is rather annoying and impractical!
Well during the installation when it was tripping, the engineer turned them all down and it was still tripping...
I am from manchester
Its a pain *** as means somebody needs to be at home because we got things in the fridge freezer
And it trips anytime can be after hours or 2 minutes
Is it an expensive thing? I am regretting to have asked for a smart meter now
My previous electric smart meter was working fine i just wanted to my prepayment gas meter to a smart one
The engineer insisted he will have to change both ?
New in home displays are compatible with previous smart meters, SMETS 1&2. Did you have a new in Home display or change of supplier?
And there have been other threads on similar subject. Some of the suppliers deny it’s an issue.
Yes, i already had a smart electric meter with the home display
So after he did put the new electric he gave a new home display now showing both electric and gas usage
Reply to Rcd tripping with no switch on after smart meter installarion in the UK Electrical Forum area at ElectriciansForums.net
Thank you to littlespark for clarifying my mumbo jumbo. Just to say that being on a dual tariff means you will typically pay more for electricity...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
