RCD wiring into fuse box | Page 4 | on ElectriciansForums
Discuss RCD wiring into fuse box in the UK Electrical Forum area at ElectriciansForums.net
J
jrli2008
Just need some clarification...
installing a 8kw electric shower, none previously fitted.
only has a older style fuse/trip box (1989 build)
In taking power from this fusebox, where should it come from and I was just going to install a separate RCD, but would I need a MCb too?
ta guys
Does anyone else find the idea terrifying of a DIYer / inexperienced electrician swapping out his live meter tails to Henley blocks probably using B&Q non-voltage-insulated tools?!
You might shrug and say "its up to him" but it isn't, as has previously been mentioned this would be illegal work!
Reply to RCD wiring into fuse box in the UK Electrical Forum area at ElectriciansForums.net
Wallbox Fuse Box Lite Single Phase has anyone used one of these? I've installed one feeding a Pulsar Max, the Pulsar Max is set to 32Amp max. The...
L
My Understanding is the 6 Months interval is IET Guidance and this wording is incorporated onto the label which is a requirement in 514.12.2 where...
