RCDS in hi rise flats | Page 2 | on ElectriciansForums
Discuss RCDS in hi rise flats in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It was meant as a joke as he is on the 12th floor!
:49:
Indeed . without starting a riot fella, chill out please and yes i have the book and knowledge.nuff said.
thank for your sometimes humorous replies guys ,,,Keep pulling yer wire
Well.... you could argue that if the install was done to the 15th regs and no outdoor use of sockets, then its OK...... until you want any extra sockets!
You cant tell what is a joke and what is serious nowadays with the competence of some who hold the Electrician title so in respect its easy to catch people out all down to the sad state of the industry :/
Just TT the whole flat,your earth electrode connection is that nice,flat copper strap,running vertically past all the bedroom windows...:conehead:
He's going to need a bloody heavy extension lead to overcome the volt drop,12 floors down to hoover his car,getting 2.5 flex into a plug top is going to be a nightmare.lol
Ohhh thats easy! Even seen 2.5mm cable in a 13a plug top! If you think it...Then it can be done! lol
Duraplug. 13 A plugs are designed for 2.5mm flex.
If you need bigger make a 13A to 16A commando adaptor, then a 16A lead with a 16 to 13 adaptor at the other end.
Or you could hire from us, we've got adaptors that can get you from 13A up to 125A commando and even 400A powerlock if you need
Reply to RCDS in hi rise flats in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
No, that is part of a different earthing system, don't mix the different earthing systems unless you have given proper engineering consideration...
davesparks
