RCDS in hi rise flats | Page 3 | on ElectriciansForums
Discuss RCDS in hi rise flats in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
He's going to need a bloody heavy extension lead to overcome the volt drop,12 floors down to hoover his car,getting 2.5 flex into a plug top is going to be a nightmare.lol
No need for a heavy cable. Just order a 110V tool and plug it straight in! :biggrin:
Afternoon Chaps .
Just a quickie lol. Can you verify that you do not need to install a RCD in a flat on the 12th floor of a hi rise block.. Thanks guys
It all depends whether the wiring is enclosed in earthed metallic conduit, MICC, SWA or equivalent, or otherwise mechanically protected, and not supplying equipment or accessories in a room containing a bath or a shower. Only the designer (you?) can decide.
Reply to RCDS in hi rise flats in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
No, that is part of a different earthing system, don't mix the different earthing systems unless you have given proper engineering consideration...
davesparks
