RCD's on farms | on ElectriciansForums
Discuss RCD's on farms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
Jimmyb
Hello, was wondering what people thought about a cable supplying the farm buildings, i need to replace the cable so it now be a 16mm swa from service head area, across the garden and into the 1st shed, i was look ar brb and saw reg 705.411.1 (iii) which says all other circuits require 300ma rcd protection will this apply to the sub main cable or not.
many thanks
What earthing arrangements have you at the service head ?
If you have a TN arrangement you could in fact protect the SWA and do without the RCD protection for it.
That was my plan but the reg states : 'in all other circuits, RCD's with a rated residual current not exceeding 300ma'
My thoughts was if i was using a rcd to protect for the sub main cable then it had to be 300ma or less but im not as its tn system but it does say in all other circuits so still not sure.
For what its worth, this is my interpretation:
For circuits with sockets less than 32A - 30mA RCD
For circuits with sockets greater than 32A - 100mA RCD
Everything else (including sub mains) - 300mA RCD
My guess, is that this is the RCD level for fire protection - farms usually store flammable materials
Thats what i thought as well just didnt want to have to buy a rcd to replace the switch fuse as it isnt on the farm until the cable enters the shed and then its goes striaght into the board.
so even with the earthed outer sheet of the armouring you still need to rcd protect the sub main ?
Will probably get shot down now , but the way i interpret it is yes .
We always bring the main tails in to a 100 to 300 ma s type before anything else, as yellowvan man put it, is how i see it too .
The type S is for discrimination , and we always TT all boards in the installation !
Would like to hear others opinions on how we do it ?
I normally bring the sub main from house and then tt everything from subboard onwards with s type 100ma but look like im gona have to start with rcd at source.
Do you also need to rcd protect the house with 300ma or less rcd, if yes how long has it been like that because ive not come across any yet
Reply to RCD's on farms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
