RCD's on farms | Page 2 | on ElectriciansForums
Discuss RCD's on farms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi,
See page 46 in GN7, this shows the supply installation main DB (incoming supply), and this diagram explains all, basically 300mA rcd's feeding all submains related to agricultural (out) buildings, whether this main DB happens to be located in a residential building or not.
Hi,
I agree, I was trying to point out that the house itself doesn't need the 300mA RCD.
Reply to RCD's on farms in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Regulations notwithstanding, the only thing in those pics that is likely to be affected by sheep is the trailing flexibles on the ground from the...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
