RCOCB BS 4293 | Page 2 | on ElectriciansForums
Discuss RCOCB BS 4293 in the UK Electrical Forum area at ElectriciansForums.net
banny07
Hi Guys.
I went to see a job today where customer wanted to replace front plate of sockets and switches. Switches has no cpc but cpc is present in the cieling roses. As I opened consumer unit the main switch was 80A 2 pole RCOCB bs 4293 which has 100mA rated tripping current and 2000A breaking capacity. My question " Is it acceptable in dwellings". customer doesn't want to upgrade consumer unit. Please advise . Thanks in advance
If the RCD works, I'd get on with it and get out of there!
If it doesn't, this is one where you could easily open a large can of worms that I'd personally choose to keep shut. It would be a rather challenging CU change if it turns out to be required. (Inset CU and looks like conduit for CPC). It's fairly likely the 100ma RCD is for fault protection of a TT system, or maybe it was TT once and is now PME.
I'd do a Zs@DB (remembering there could be parallel paths). If inconclusive I'd test local incoming earth (disconnected) with main switch off .
If I got higher that TNS numbers back I wouldn't get involved beyond advising in writing to customer that the fault protection of their installation couldn't be confirmed and more work is needed to investigate and rectify.
Reply to RCOCB BS 4293 in the UK Electrical Forum area at ElectriciansForums.net
I think there is a little truth in what the guy in the video says, but he makes more out of it than he should. A N-E fault on a circuit protected...
