Re-wire advice | Page 3 | on ElectriciansForums
Discuss Re-wire advice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks guys,
only meant to be 1 smoke circuit, sorry been a long day, so 15 circuits.
yep i have an open house so always full of family and friends.
think i will tweak a few circuits as suggested.
thanks
craig
he might have ten kids
What about it?? Since when does Kids = circuits??, ...I thought we were looking a standard 3 bed semi?? 16 circuits is gonna mean an awful lot of cable and cable runs, his floor joists are gonna look like swiss cheese!! ....haha!!!
Cannot understand the mass vote against the Ring Final.
Radials are fine, but what happens if you lose the cpc at the first socket? At least the Ring Final offers a back up, albeit the Zs might be a tad high but better than nothing!
Ring finals should not be overlooked just because they cost more, are a pain in the arse to install (sometimes) or involve more testing.
chiplard: I agree with what you're saying and think that the ring final circuit has been tried and tested for nearly 70 years now, so why change what is in effect a very satisfactory means of providing multiples of socket outlets to the householder at a very cheap price and with efficiency properties that the humble radial can't provide. The only part of your input about ring finals costing more is wrong though, due to the nature of the ring final it is possible to run in effect an unlimited amount of sockets (taking into account diversity), with half the size of conductor csa compared with the radial which according to cable calcs can only provide a finite amount of sockets and is usually double the conductor csa of a ring final circuit. IMO if it's not broke don't change it, the same can be said for EEBADS as opposed to just ADS with RCD protection!
Reply to Re-wire advice in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Power off ! The switch wires will be the ones that go low resistance when the switch is turned on and go open circuit when its off.
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
