Re-Wire | Page 2 | on ElectriciansForums
Discuss Re-Wire in the UK Electrical Forum area at ElectriciansForums.net
M
MeanzBeanz
I went to look at a house the other day that is in desperate need of a re-wire. For starters the board was old fuse wire! To cut a long story short the Customer had another electrician look at it. This so called electrician took one switch off in the whole house and declared it did not need a re-wire because there was an earth in the cable! He didn't even look at anything else or get a test meter out to prove that the earth was indeed connected!
It's a disgrace! Enough said
Why all the comments about the Wylex lad
For Christs sake,its a fuse board Ill have you know,don't any of you realise the enormity of the danger
These boards can cause dermatitis and in severe cases,a persons arms and legs may fall off just by touching them
They should be removed with the utmost care,double bagged,then incinerated before they infect the whole population
Reply to Re-Wire in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
