Really struggling with RJ45 connectors. | Page 3 | on ElectriciansForums
Discuss Really struggling with RJ45 connectors. in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have fitted RJ45 connectors to either side of a piece of cat5 cable but when I test it on the laptop I get no ethernet connection. I also have a pre-made ethernet cable which works fine so I know it's my home made ethernet cable. I cut the cat5 to 12.5mm and connect both ends the same (i.e s68A)
I have practised this a few times now each with the same result, i.e. it doesn't work.
With a piece of twin and earth I could test for continuity at both ends but how do I test for continuity through an RJ45 connector?
The problems that I can see it as being are the following but I dont know which is the most likely or if there are other problems I missing?
1. Poor quality connectors, not actually making contact in the laptop or router.
2. cat 5 not actually terminated inside RJ45 connector
3. RJ45 Crimping tool not effective which leads to 2 above.
Cheers all.
[ElectriciansForums.net] Really struggling with RJ45 connectors. [ElectriciansForums.net] Really struggling with RJ45 connectors. [ElectriciansForums.net] Really struggling with RJ45 connectors.
There are uses for a "mirror opposite" cable in networking with RJ45 connectors. I'm not sure this is one of those situations, though.
Agreed on the tester.
(Removed link - SC)
Can you explain?
Back in the day, when switches and hubs weren't cheap, you could connect two PCs together using a crossover cable. If memory serves, you'd use the T568A standard on one end and T568B on the other so the cores in the connectors went something like this...
Code:
orange/white -> green/white
orange       -> green
green/white  -> orange/white
blue         -> blue
blue/white   -> blue/white
green        -> orange
brown/white  -> brown/white
brown        -> brown
These days you'd need to factor in the blue/brown pairs as well I think as for higher speeds I think they form a data path and you'd need to be careful with POE devices
Code:
orange       -> green
blue         -> blue
green        -> orange
brown        -> brown
Crossover cables are still used today in some peer to peer applications although auto negotiation has somewhat reduced their use these days
This is the big minefield these days mixing POE and data does not normally end well
Oh... before I forget... don't bother making up patch cables if you need 'em. Just buy them in... it's cheaper, easier and looks better.
Some large patch frames I have worked on you had to make patch cables of the correct length and colour if you didn't want the head of I.T. to descend on you. On one site they had a patch cable trolley with all the different coloured cables and termination kit so you had no excuse
Reply to Really struggling with RJ45 connectors. in the UK Electrical Forum area at ElectriciansForums.net
Yes, you run each socket as a point to point connection, and use a switch (it doesn't need to be PoE unless you are wanting to power devices via...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
