There is noting to bond in this building. No gas and plastic water pipes.If you look closely Mate you can see the screw holes fro a plate of some sort. A there doesn't seem to be any bonding conductors.
There will be no exposed cable what so everAs far as I am concerned you have opted for a poor installation method and they are not suitably enclosed.
I can cut a hole in the wood boad maybe. Thank you I will make it accessible
That is not the issue, you have single insulated conductors exposed to a combustible surface.There will be no exposed cable what so ever
There is no issue with the wooden board and there is no issue with a rear entry tho. It all conforms to BS7671
Hi,
Is it OK to create a rear entry in an eight way three phase BD.
Please see photo attached.
A technician friend of mine says he has never seen this done before?
Is it a plastic DB or metal one?I wouldn’t really worry about the back board being flammable, it’s probably less so than the plastic DB.
Why could the meter not be at the supply end?
