Rear Wiper motor relay wiring
Sir, Would you like to have some fun with your multimeter? We need to identify the wires on the wiper motor. What would be helpful is if you could take some resistance measurements. Select 'Ohms' on your meter and the lowest resistance scale. Check the Ohmmeter works by touching the probes together - the scale should read 0 Ohms or thereabouts - tell me what resistance you measured.
Now completely disconnect the wiper motor. Then study the attachment 'wipermotor' below. You will see three wires to the wire motor which I have labelled A, Park and Run. These are the wires we need to identify. If you have more than three wires don't go any further but do tell me.
Now label somehow the three wires as '1', '2' and '3'.
Using you Ohmmeter measure the resistance between these pairs and tell me the results:
1 and 2
1 and 3
2 and 3
1 and 2
1 and 3
2 and 3
Thats great. Thanks, I will do this tomorrow as today is 'queue at Sainsburys day' and take it to the in-laws, so bear-with as they say! :)
Finally, I've had time to take the motor off, and put it on my dining table with the multimeter. Before I start, there are 4 connections plus earth. Hopefully the attached image will show this. The wires are 1) Orange, 2) Blue with brown dots. These seem to be a park switch, perhaps. Then theres 3)Red and Light Green and 4) Blue with brown dots. going to the motor itself. Both of the Blue/Brown ones are joined so the motor has 3 wires + a seperate earth connected to the casing.
Post automatically merged:
1 and 2
1 and 3
2 and 3
1 and 2
1 and 3
2 and 3
I assume 1 is 'A (Blue/Brown)
2 is Park (Orange)
3 is Run (Red/LtGreen)
Set Multimeter to 20Ohms, and resistance of touching probes is 0.6
1 and 2 = 1
1 and 3 = 53
2 and 3 = 1
Whaddya think? :)
Hello. Greetings from London.
You tell me the the motor has effectively 3 wires and a fourth one connected to the casing.
If you can label the wires 1, 2, 3 and 4(the one connected to the casing)
would you please measure the resistances:
1-2
1-3
1-4
2-3
2-4
3-4
:cool:
When you have taken these measurements would you be able to apply 12V across 1 and 3 to power up the motor briefly to move it away from the parked position?
And then take the same set of paired resistance measurements again please?
I need a set of readings for the wiper in the parked position and another set for when it is away from the parked position.
I will not be able to look again at what you send me until tomorrow morning I'm afraid.
1-2
1-3
1-4
2-3
2-4
3-4
:cool:
Ok.. Here goes :)
1= Blue/Brown
2= Orange
3= Red/LtGreen
4= Black
1-2= 1
1-3= .05
1-4= 1
2-3= 1
2-4= 1
3-4= 1
Applied power with probe (+ve) to 1 and 3 and the motor moved.
:D
1-2
1-3
1-4
2-3
2-4
3-4
:cool:
Hi thats no problem, I really appreciate this. So to recap, Parked readings:
1-2= 1
1-3= .05
1-4= 1
2-3= 1
2-4= 1
3-4= 1
And unparked:
1-2=1
1-3=.02
1-4=1
2-3=1
2-4=.03
3-4=1
Have a great evening. Beef Rendang Curry for us!
Thanks again :)
Good morning. Even with a good strong coffee I regret I am confused by your resistance measurements. When you report '1' do you means 1 Ohm or what is displayed on your meter which if it is a digital multimeter often indicates 'infinity' or open-circuit?
The digital meter(DM) will display '1' if the resistance is greater than the current range scale - you said earlier you selected the 20 Ohm range scale so any reading above 20 Ohms would display a '1' on a DM.
And then sometimes you report 0.05, 0.02 and 0.03. Are these Ohms or kiloOhms?
To clarify things for me then could you take the readings again and tell me which range scale you have used and whether 1 refers to 1 Ohm of infinity? Again for parked and unparked.
Sorry to muck you about.
Regards
Marconi
A third cup of coffee may have helped me.
I have attached a drawing showing what I think each wire is for on the wiper motor and how these are connected to the Lucas relay. There is also a table of resistance measurements which I expect you will measure if my drawing and wire colours are correct. The measurements are for when the motor is disconnected from the relay and loom. If the wire colours are difficult to make out they are numbered as you did in your last message to me.
I am having difficulty attaching the image. Will try later.
Hi Marconi
Thats awesome, and I have been having trouble attaching images too. I set it to 20Ohms on my digital multimeter. Thats the setting it stayed on for all readings.
The diagram will be very helpful, and yes, no problem to retake readings, and set the meter to your preferred scale too.
Cheers
Wait until you see my diagram before taking any more readings. I don't think the attachment problem will be fixed today so don't waste time looking for it until tomorrow onwards.
Ok, no worries, I am puppy sitting and have fitted other electrical items today (that work!) like a fuel sender etc. Thanks again :)
3wheeler: Still having problems attaching file - it keeps saying 'not an image as expected...'
If you send me a Private Message with your email address I can send you the coloured diagram that way. Or I can post it to you.
Hi my email is in a message
, but I had exactly that message for all my attachments, so it may work still. Give it a go, but no worries with the email. Thanks for trying!
(I am experimenting posting pictures to the web and then publishing a link to them as suggested by pc1966 - thank you for the tip. I posted to google photos.)
This is a diagram of what I think is the wiring for the OP's rear wiper motor on a Robin Reliant. It has an interesting feature if you fancy studying the circuit. Auto-electricians will be well aware of it but it was a new discovery for me to find it used in car-electrics.
Sign in - Google Accounts - https://photos.google.com/photo/AF1QipMRpMPurr_9kSdGfObgbaV7ZvtZ910GEJ2kDor2
Not the best of photos but if one zooms in the clarity improves.
I hope that threewheeler will see this and post some pictures of his refurbishment project.
(I am experimenting posting pictures to the web and then publishing a link to them.)
Hi Marconi, I'll take a look. I have had to take a couple of days off it, as the weather here isn't so good, and I don't have a garage! Cheers
