Reasonable operation limitations in Domestic EICR? (Live testing only)
Dartlec
This old chestnut
Client decided they couldn't wait a few weeks for me to do an EICR so got someone 'off the internet' who immediately failed it (probably fairly, since its a house, with fuse wire protection on all circuits it appears).
Looking at the report for a second opinion and under operational limitations is:
"only live testing done due to fish tank not being allowed to being turned off" (sic)
and they carried out Zs only on all circuits (no idea if the fish tank also has lighting, boiler and cooker connections!)
Also didn't take rfc resistances for 2 different socket circuits, when I assume the fish tank is only connected to one....
Obviously this happens on commercial EICRs quite often where machines have to be left on, but is this a reasonable limitation on domestic cases? I'd say it's at least not in the spirit of the idea of EICRs as they are meant to be used for the domestic rental sector.
The report is probably reasonable otherwise, with a couple of arguable C2s but some clear ones too..
£710 quote for new CU and bathroom lights is not the worst rip off I've seen either - if a bit overkill since they've also done the report. (though depends if that is RCBO all circuits or Screwfix special)
I wouldn't consider a 'live testing only' certificate to be a reasonable test of a domestic electrical installation, but maybe others do?
This fish tank thing...when I posted the thread about that a couple of days ago I did not mention the set up. This was not just a fish tank with a heater in it. There were gas cylinders in a cupboard below the tank and other "things" don't know what they were. I was told if I switch of they will die rapidly because of the gas thing going on. Sorry to be so vague but I did not have a clue what I was dealing with. Thought it best to keep well away from any interference with it at all. He may have been exaggerating or telling the truth I don't know. But I could just sense if I did one thing wrong there would be trouble!
Still begs the question what happens if there’s a power cut?
I've seen a lot worse to be fair - though always more fun to critic other paperwork than double check my own...
Not sure why the LIM for Ze though - not like they even did Zs at the board...
Bet the bathroom downlights are actually over 2.25m anyway, or not more than a C3 anyway
I'll go and take a look to ensure they haven't completely misread what's there - and then quote well under £710 for a consumer unit change which should solve any problems.
And since there are two socket circuits, they could surely have rigged something up to test both -
I'll have to try to rig something up for the poor fish when changing CU I guess.
I love the BS3036 main switch.
I could supply an all RCBO board with SP and DP RCBO's and 2 blank ways for £260 on 30%GP + installation.
Ze lim, hard to pick up the phone to ask isn't it? By enquiry is an option.
It gets better -
Only finally had a chance to work out the quote on this job and sat down to review the photos I took on my short site visit compared to the original "EICR"
The schedule on the EICR
The picture I took:
FFS
60898 MCBs not 3036 - 7 circuits, an additional stray circuit to smoke alarm and an 'outside light spur' which bears no relation to the board...
Not like they took the MCBs out and accidentally went by the colours of the shields either.
Now I honestly have no idea whether anything on the form can be trusted...
Stupid thing is they could have actually taken the front of the board off without turning things off if they'd really wanted to - and they clearly had no way of confirming the cable sizes without doing so.
This is a firm with NAPIT accreditation, trustmark and Checkatrade 'approved'.....
The 20A may be a 3871/2?
yes I think you're right - it's fairly clearly NOT a 15A 3036 though ?
Daft thing is that the report outcomes were more or less right (new consumer unit needed) - just that the schedule is clearly dodgy - maybe they expected to redo it when changing the board (£710 for board and 4 new lights in bathroom)
That's not a completely outrageous price, though a bit high for the area, depending if that was a £50 board or a £250 one - or indeed a certificate worth the paper it's written on!
Dartlec,
Dartlec,
