Reference method | on ElectriciansForums
Discuss Reference method in the UK Electrical Forum area at ElectriciansForums.net
Dave 85
What reference method would you guys put for standard house wiring (T&E through loft/underfloor/chased in walls behind capping)
Cheers guys, another quick one: When you put the R1+R2 reading for an RFC on the cert, do you put the reading obtained with the R1 and R2 cross connected or just bridge between R1 and R2 at the furthest point and take the reading at the C/U (surely this reading would give you the true earth fault resistance). I understand how to do RFC testing just never been 100% as to which result I record.
on a |RFC all the R1+R2 readingds will be the same whatever socket you measure at. simply because of the cross connection at the |CU. (not allowing for spurs)
On an RFC it will be the cross-connected reading which will give you the true reading due to resistances in parallel, ie. (r1+r2)/4
On a radial it will be linked R1+R2
As others say, if you have more than one install method along a circuit always go with the one with the lowest current-carrying-capacity for the cable you're using.
I did say "cheers guys" to the first answers but here it is again...
cheers guys
Still wondering though...
What would you guys usually put on the cert of a standard domestic property as reference method, B or C? I find the descriptions in the regs a bit ambiguos
A kitchen or downstairs ring would be under the floor boards and down the walls,so ref method C,likewise a cooker circuit
An upstairs lighting circuit would be through the insulation so the 100s club would be more likely,likewise a shower cable
If its a beautiful surface trunking or conduit job,ref B,capping over the cable,still C
cheers guys
No problem Dave. I was referring to the RFC question, which you seemed a little confused about. Just wanted to make sure you understood what I had said, as you hadn't responded :)
Reply to Reference method in the UK Electrical Forum area at ElectriciansForums.net
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
Better off with the click prw213 as it has twin screw termination.
