Hi Chaps thanks for looking.
I am presently rectifying all the faults found in 21 or so properties found under PIR, however one is quite irritating to cure not to say potentially expensive this is the old chestnut of doubling up circuits at the board, I have spoken to nikky they are adamant its a code 2
314.4 BGB covers this and it's hard to argue but if you read App 15 it states an unfused spur ( A socket?) can be connected at the board albeit only one, but 521.8.2.seems to contradict this.
Options, bigger board, split the tails and new small board, remove the doubled up circuits and use the now spare way to feed a new small board, what do you think lads ?
Cheers S
Cheers S
