Reinstating / making good | Page 4 | on ElectriciansForums
Discuss Reinstating / making good in the UK Electrical Forum area at ElectriciansForums.net
UK
Hi all,
in the statement of works I have from my electrician, it says:
"Re-instatement of damaged areas: all areas of the house where it is necessary to cut wall chases and sink boxes etc will be restored to a condition suitable for redecoration."
I did not thoroughly define what this means prior to the work starting, and we are now approaching the end.
I wanted to find out what condition would you all believe to be a reasonable way to leave the damaged areas to capture the spirit of that quote? Bonding plaster only, or finishing plaster? If he just leaves bonding plaster, should I push for finishing plaster? I can't decorate directly on top of bonding plaster, would need finishing plaster or filler first, so my thinking was that it should be up to a paintable standard, but I might be expecting too much.
many thanks!
Oh no not another one, I worked with a bloke like that once, he served his time as a Sparky wiring up passenger carriages at some big rail depot, always insisted on the screw slot being all the same plane, pxssded him off no end when I put all mine at 45Degrees, funny never got on that well after the fallout from that episode. His nickname was Thrush, jeez he was irritating.
Nobody cares a flying ****** or notices which way the screws are.
I super glue the white screw caps on the sockets and switches just to be a see you next Tuesday..........
There are sooo many replies I could do for this..... but I'll be a good boy and keep stum..
Reply to Reinstating / making good in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
