Reinstating / making good | Page 5 | on ElectriciansForums
Discuss Reinstating / making good in the UK Electrical Forum area at ElectriciansForums.net
UK
Hi all,
in the statement of works I have from my electrician, it says:
"Re-instatement of damaged areas: all areas of the house where it is necessary to cut wall chases and sink boxes etc will be restored to a condition suitable for redecoration."
I did not thoroughly define what this means prior to the work starting, and we are now approaching the end.
I wanted to find out what condition would you all believe to be a reasonable way to leave the damaged areas to capture the spirit of that quote? Bonding plaster only, or finishing plaster? If he just leaves bonding plaster, should I push for finishing plaster? I can't decorate directly on top of bonding plaster, would need finishing plaster or filler first, so my thinking was that it should be up to a paintable standard, but I might be expecting too much.
many thanks!
Thought smuggling phones and drugs in to prison in "that" cavity would be more profitable then polyfilla.......
How big has your bum got to be to do that...... What next... an Ipad???
Watched a TV program there a bloke went to hospital with an old TV value stuck up there..... Apparently he said he was fixing the TV and sat down on it....
always did wonder where that missing PL509 went.
[ElectriciansForums.net] Reinstating / making good
I worked with a guy who decide to drill one of those square office fittings on his lap the drill slipped and he damaged his John Thomas.......
I don't believe that you lot are that pedantic regarding switch and socket screws for one moment which position do you screw them to?
I do insist on them, for a couple of reasons other than it just looking better. Horizontal rather than vertical FWIW.
1) Only make them horizontal when levelling them. This way we know what's been levelled.
2) In the event of a call back, I know if the plates have been removed as no one else will have bothered to keep them horizontal.
Reply to Reinstating / making good in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
