I may have confused you both. I wrote the NO, NC and COM as notes to myself of the relay layout without power so I wouldn't confuse myself.
What I read and watched on youTube is that without power 85 is NC. When you add power 85 becomes closed and 87 becomes NC and 85 is now NO .
Hi
If you look at the relay image I posted, you will see that the magnetic coil that operates the contacts is wired to pin 85 and 86, and you have correctly drawn your ignition powering those.
But in your latest message above, you are referring to 85 as a contact, which is incorrect. It is normally the ground of the coil, as you have drawn.
Either you are watching a video about a differently numbered relay, the video is wrong, or you may be slightly muddled with the numbers and the naming.
The common of the switch is 30
The NO contact is 87
The NC contact is 87a
The above nomenclature is fixed by the design of the relay.
The only thing that changes when the relay operates is which circuit is closed, and which open - they just swap as you know.
In your case, unlike most applications of relays, you want to use the NC contacts, as you want activation when the ignition is off. So the switch in your circuit comprises contacts 30 and 87a
Your latest drawing is fine for the type of relay called B above, which corresponds with your circuit. If you have bought the relay already, the schematic and pin numbering is often shown on the side of the case - so worth checking they tie up with your diagram!
Incidentally, I generally find it useful to draw out the circuit I want to implement, using traditional electrical symbols, not worrying about the physical wiring and pin numbers etc. And then when I'm satisfied I have the correct 'design', I annotate things like pin numbers and wire colours second. I find I need to understand the circuit first. Just from a physical wiring diagram it can be difficult to grasp what is happening - just my thoughts - excuse the ramble!
The only way I know how to do that is...
Sticky Notes or timer light switch.
Is there more of an elegant way of doing it. BTW. The solenoid only uses .75 amp.
The only thing I can suggest is if there is a source of power that goes off only after the van is locked (my car has a supply to the dash that stays on for a while when sitting in the car with the ignition off, but after I exit and it's locked, that supply goes off)! Unless of course you want this thing to be operating while the van is locked ?
Here is the latest updated drawing.
That looks good to me
Good luck with the project ?
