C
connordev
hi, i am connecting a time delay relay onto a lighting circuit. i am going to have a switch on the circuit, when you switch the light on it should go on and stay on, until the switch is switched off again. when the switch is switched off, i want the light to stay on for ten minutes then go off. i purchased a time delay relay with normally open and normally closed contacts. the contacts on the relay are 15, 16, 18, a1, a2, b1. can you help? does anyone know what cables go where? also there is a dial on the relay with different settings, wt, ws, r, e, etc. i havent a clue which one to set it to?
