Remote controlled light switch | on ElectriciansForums
Discuss Remote controlled light switch in the UK Electrical Forum area at ElectriciansForums.net
Blackpool,Lancashire.
Could anyone recommend a remote controlled light switch? It must be able to dim and switch up to 320 watts,preferably not be too deep at the back and not cost a fortune.Also there is no neutral at the switch so it would have to be a live in and live out one.
The ones i have looked at on Ebay all seem to have deep backs(ie need 35mm back boxes).
The only one i have seen is made by Varilight.Has anyone used them?
i fitted one of these last month. the one i used was not a dimmer, but they do do dimmers. also no neutral required for the non dimmers.you'll need to check if that's the case for the dimmer ones.:
KONOQ Luxury Glass Panel Touch LED Light Wall Switch :REMOTE ON/OFF, 1Gang/1Way | eBay - http://www.ebay.co.uk/itm/322132507000?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
These looks good, was it the remote control version you fitted? Was the range good?
Never used one but came across this, supposed to fit in standard back box.
eBay 401053690711
Reply to Remote controlled light switch in the UK Electrical Forum area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
