removing a circuit | on ElectriciansForums
Discuss removing a circuit in the UK Electrical Forum area at ElectriciansForums.net
S
still learning.
Hi, what paper work would you need to leave the customer (if any), if you were taking out a circuit in a house. For example, someone is moving house and they are taking their shed with them. The shed has lights which has it's own mcb in the cu, if that circuit was taken out is there any paperwork to be given as none of the other circuits have been altered in any way.
i would go with none except invoice
want do you want ? a freakin engraved brass commemorative plaque above the cable ?
"then at the shed end just coil the cable up and leave it"
But the shed isn't there any more! So are you suggesting putting tape over the MCB and leaving a random coil of cable in the garden??
Madness.
Disconnect all cores at the DB is the minimum I'd recommend
Madness.
i'm sure he meant taping up cable end in CU but leaving the cable out of the wall ready for the new homeowners shed.
chilax M , theres hours more of lunacy still to come , you need to pace yourself lol.
Not sure I can cope with 3 hours on here. Too many rude idiots or numpties on here.
I'm off somewhere with a better quality of members
Reply to removing a circuit in the UK Electrical Forum area at ElectriciansForums.net
Hello Brianmoooore, Thanks for yor reply - Sorry that I did not see your message until today - the Forum replies notification emails about your...
If you think that's bad you should try manually winding out the safety curtain in a theatre.
davesparks
