E
Earthstore
thanks that makes perfect sense!!!! but why would you fit a small 2way consumer unit if there are 2/3 spare ways in the DB not knowing the rcd will trip when its all installed with the voltis unit
Because then the PV would be connected after the Voltis, so any export would be trying to go back through the Voltis unit, which it can not do.
I believe it is quite clear in the instructions about fitting PV with a Voltis (I may be wrong).
You would not fit your 16a PV MCB on the RCD side just because there was a space, would you?
I hope this helps.
