View the thread, titled "Replacing DB" which is posted in Australia on Electricians Forums.
A
aes2011
So a cu change consists of:
1. Pir or eicr first, so for a 12 way board done correctly will take the majority of an 8 hour shift?
2. Correct remedial work if any?say another few hours
3. Change CU, say 3 hours
4. test all circuits, 3 hours again.
So two days for a CU change. Is this normal practice?
That's a little more like it, although you may be over egging the pudding now.
Go to www.esc.org.uk and look for the best practice guides. There is one for changing a CU which will point you in the right direction.
However, as with all things electrical, it's how well you want to sleep at night that really counts.
Reply to the thread, titled "Replacing DB" which is posted in Australia on Electricians Forums.
