K
kshah86
hello, i need some help. im a trainee electrician. you probably going to say i should know this but i just want to make sure.
basically im changing an old consumer unit in a friends garage for a new one. garage is in the back of garden. the power to the unit is coming from the main consumer unit which is in the house ( roughlt 10 to 15 meters distance between main and garage boards). right now the garage is feeded from a 45a mcb on the main consumer unit.
currently on garage consumer unit is 1 main ring and 1 lighting circuit
im going to buy a garage consumer unit from screwfix.
MK 6-Way 8-Module RCD Garage Consumer Unit with 6 MCBs
this come with 1 x 63A 30mA RCD. this will be the main isolation switch so my question is this:
will this be ok as it is coming from a feed which is running of a 45a mcb?
