J
Jamie3032
Hi, has anybody had any experience with repositioning the electrical meter and main fuse within a domestic property and the costs involved, thanks
Chester; Living proof that the Welsh shag sheep...just saying
Except Chester is in England!
Tenner says they dont
Off you pop then. Don't forget to record the call so you can share it with the forum.![]()
Well worth the moneyHa, crackin, ill look forward to the tenner, thanks very much
Nice touch, Ive worked with a lot of sparkys from Newcastle way, the majority of whom had trouble farting and breathing at the same time...just saying
Absolutely ive worked and lived in chester, and there was quite a few monkeys who couldnt do the same either, but wasnt sure if they were from the zoo or the housing estate,,,,just saying
Sometimes a little common sense is what is needed in these situations...
This reminds me of a house I was at around 8 months ago. The mad old fella that lived there wanted all the cct cables untangling and tidying up as they were in a right old mess. He said they had always been like that.
At the time I was puzzled as to why they were in such a mess. That was until I found out off the plasterer that the old fella had moved the intake, meter and DB six feet across the hallway in one fell swoop. Supply fed from overhead lines into house through loft. I reckon he must have had to rotate it through 360 degrees to get it to the new position.
As soon as I found out what happened I walked. Cant be doing with lying customers.
Wasn't in Chester, was it?
Are you On Drugs?
Reply to the thread, titled "Repositioning Main Fuse and Meter - Domestic Property" which is posted in Domestic Electrician Forum on Electricians Forums.
