dedwrinkle
I have I have about an 800 foot run. What would it take to get adequate amperage and voltage at the end of that for 120v 30 to 50 amps?
Discuss requirements for a long run in the UK Electrical Forum area at ElectriciansForums.net
dedwirnkle 800 feet is a long way from your source so at 50 amps you would need a minimum of 250 MCM wireI have I have about an 800 foot run. What would it take to get adequate amperage and voltage at the end of that for 120v 30 to 50 amps?
I looked that up it's $2900 for 500 feet and I need 3200 ft 4x800 which equates to $18k that's insanededwirnkle 800 feet is a long way from your source so at 50 amps you would need a minimum of 250 MCM wire
I’ll tell you what why don’t you buy # 8 and run that 800 feet and put 50 amps and see how that works for you. There is a formula for voltage drop, look that up and see what size wire you need for that. Insane is pulling 800 feet of wire just for 120vac. Buy a generator and see how that works for youI looked that up it's $2900 for 500 feet and I need 3200 ft 4x800 which equates to $18k that's insane
No to be a dick or anyting that's just a crazy amount of money was all I was saying geez it's how you talk to everybody?I’ll tell you what why don’t you buy # 8 and run that 800 feet and put 50 amps and see how that works for you. There is a formula for voltage drop, look that up and see what size wire you need for that. Insane is pulling 800 feet of wire just for 120vac. Buy a generator and see how that works for you
Reply to requirements for a long run in the UK Electrical Forum area at ElectriciansForums.net
